Reversionary Display Modes
When at least two AXIS™ flight displays are installed, failure of one GDU™ will cause one or more of the remaining GDU(s) to automatically display a reversionary format. In Reversionary Mode, a display will show a split screen format with PFD/MFD/EIS windows (if EIS is installed). Radio tuning, audio panel, and transponder controls may also be displayed if the remaining GDU(s) are able to interface to these equipment.
Due to interface limitations of the base GDU 116B, there are some installations where a combination of GDU 116B, GEA 110, and GSU 75 may result in loss of EIS and/or primary ADAHRS display in Reversionary Mode. The following table describes display reversion behavior for different combinations of equipment.
Table 5: AXIS Display Reversionary Modes
Display Configuration Single Display Failure Effects Exceptions
Single PFD If PFD fails, all PFD/MFD/EIS function is lost, use standby instruments for attitude/air data
PFD1/PFD2 If PFD1 fails, PFD2 will enter Reversionary Mode If a GEA 110 is installed with GDU 116B as PFD2, loss of PFD1 results in loss of EIS
If PFD2 fails, PFD1 will enter Reversionary Mode
PFD/MFD If PFD fails, MFD will enter Reversionary Mode If a GEA 110 is installed with GDU 116B MFD, loss of PFD results in loss of EIS
If GSU 75 and pneumatic standby instruments are installed with GDU 116B MFD, the MFD cannot display ADAHRS data in Reversionary Mode
Note: if GSU 75 is installed with G5 or GI275 and a GDU 116B MFD, the MFD can only display standby ADAHRS data in Reversionary Mode
If MFD Fails, PFD will enter Reversionary Mode
PFD/MFD1/MFD2 If PFD fails, MFD1 and MFD2 will enter Reversionary Mode If a GEA 110 is installed with dual GDU 116B MFD’s, loss of PFD will result in loss of EIS
If GSU 75 and pneumatic standby instruments are installed with dual GDU 116B MFD’s, neither MFD can display ADAHRS data in Reversionary Mode
Note: if GSU 75 is installed with G5 or GI275 and dual GDU 116B MFD’s, the MFDs can only display standby ADAHRS data in Reversionary Mode
If MFD1 or MFD2 fails, PFD will enter Reversionary mode
PFD1/MFD/PFD2 If PFD1 fails, MFD will enter Reversionary Mode and display data from ADAHRS #2 If a GEA 110 is installed with GDU 116B as MFD & PFD2, loss of PFD1 will result in loss of EIS
If MFD or PFD2 fails, PFD1 will enter Reversionary Mode
Refer to Appendix A for more information on system specific alerts and failures. Refer to the AXIS installation manual for more information on reversionary information based on installation options.
190-03123-01 Rev B
July 2026
