Specifications
All Models
Temperature range |
From -15° to 55°C (from 5° to 131°F) |
Material |
Die-cast aluminum and polycarbonate plastic |
Water rating |
IEC 60529 IPX7 1 |
Input voltage |
From 10 to 32 Vdc |
Fuse |
6 A, 125 V fast-acting |
NMEA 2000® LEN @ 9 Vdc |
2 |
NMEA 2000 Draw |
75 mA max. |
Wireless frequency |
2.4 GHz @ 19.5 dBm nominal |
7x07 Models
Dimensions (W × H × D) |
22.2 × 14.2 × 6.1 cm (8.75 × 5.6 × 2.6 in.) |
Display size (W × H) |
15.5 × 8.6 cm (6.1 × 3.4 in.) |
Weight |
1.13 kg (2.5 lb.) |
Max. power usage at 10 Vdc |
24 W |
Typical current draw at 12 Vdc |
1.5 A |
Max. current draw at 12 Vdc |
2.0 A |
Compass-safe distance |
80 cm (31.5 in.) |
Memory card |
2 microSD® card slots; 32 GB max. card size |
7x08 Models
24.4 × 16.0 × 7.6 cm (9.6 × 6.3 × 3.0 in.) |
17.8 × 10.2 cm (7.0 × 4.0 in.) |
Weight |
1.41 kg (3.1 lb.) |
27 W |
1.8 A |
2.3 A |
70 cm (27.6 in.) |
Memory card |
2 SD® card slots; 32 GB max. card size |
7x10 Models
28.9 × 20.6 × 7.6 cm (11.4 × 8.1 × 3.1 in.) |
21.8 × 13.5 cm (8.6 × 5.3 in.) |
Weight |
2.36 kg (5.2 lb.) |
30 W |
1.95 A |
2.5 A |
65 cm (25.6 in.) |
Memory card |
2 SD card slots; 32 GB max. card size |
7x12 Models
33.0 × 22.6 × 7.9 cm (13.0 × 8.9 × 3.1 in.) |
26.2 × 16.3 cm (10.3 × 6.4 in.) |
Weight |
2.72 kg (6.0 lb.) |
36 W |
2.5 A |
3.0 A |
65 cm (25.6 in.) |
Memory card |
7x16 Models
42.7 × 27.5 × 8.6 cm (16.8 × 10.8 × 3.4 in.) |
34.5 × 19.3 cm (13.6 × 7.6 in.) |
Weight |
4.3 kg (9.5 lb.) |
57.2 W |
3.82 A |
5.24 A |
85.0 cm (33.5 in.) |
Memory card |
