J1939 Engine Network Connection Considerations
NOTICE
You must use a Garmin® GPSMAP® J1939 accessory cable when connecting the chartplotter to the J1939 engine network to prevent corrosion due to moisture. Using a different cable voids your warranty.
NOTICE
If you have an existing engine network on your boat, it should already be connected to power. Do not add any additional power supply.
This chartplotter can connect to an engine network on your boat to read data from compatible devices such as certain engines. The engine network follows a standard and uses proprietary messages.
You should connect only one chartplotter to one engine network. Connecting more than one chartplotter to one engine network may result in unexpected behavior.
The port labeled J1939 is used to connect the device to the existing engine network. You must route the cable within 6 m (20 ft.) of the engine network backbone.
The Garmin GPSMAP J1939 accessory cable requires connection to a power source and proper termination. For more information on connecting to your engine network, see the manufacturer's engine documentation.
Cable connector pinout with callouts
Pin
Wire Color
Description
Callout number 1
Bare
Shield
Callout number 2
Red
Power, positive
Callout number 3
Black
Power, negative
Callout number 4
White
CAN High
Callout number 5
Blue
CAN Low
GUID-6E54DB9C-BAE7-4C40-90F3-2D22E623703D v6
January 2025
