NMEA 2000 Considerations
If you are connecting this device to an existing NMEA 2000® network, the NMEA 2000 network should already be connected to power. Do not connect the NMEA 2000 power cable to an existing NMEA 2000 network, because only one power source should be connected to a NMEA 2000 network.
If you are connecting this device to an existing NMEA 2000 network or engine network by another manufacturer, you should install a NMEA 2000 Power Isolator (010-11580-00) between the existing network and the Garmin® devices.
If you are installing a NMEA 2000 power cable, you must connect it to the boat ignition switch or through another in-line switch. NMEA 2000 devices will drain your battery if the NMEA 2000 power cable is connected to the battery directly.
This device can connect to a NMEA 2000 network on your boat to share data from NMEA 2000 compatible devices such as a GPS antenna or a VHF radio. The included NMEA 2000 cables and connectors allow you to connect the device to your existing NMEA 2000 network. If you do not have an existing NMEA 2000 network you can create a basic one using cables from Garmin.
If you are unfamiliar with NMEA 2000, you should read the “NMEA 2000 Network Fundamentals” chapter of the Technical Reference for NMEA 2000 Products. You can find this document using the “Manuals” link on the product page for your device at www.garmin.com.
The port labeled NMEA 2000 is used to connect the device to a standard NMEA 2000 network.
Item |
Description |
NMEA 2000 compatible Garmin device |
GPS antenna |
Ignition or in-line switch |
NMEA 2000 power cable |
NMEA 2000 drop cable |
12 Vdc power source |
NMEA 2000 terminator or backbone cable |
NMEA 2000 T-connector |
