Lamp and Horn Connections
The device can be used with a lamp, a horn, or both, to sound or flash an alert when the chartplotter displays a message. This is optional, and the alarm wire is not necessary for the device to function normally. When connecting the device to a lamp or horn, observe these considerations.
The alarm circuit switches to a low-voltage state when the alarm sounds.
The maximum current is 100 mA , and a relay is needed to limit the current from the chartplotter to 100 mA .
To manually toggle visual and audible alerts, you can install single-pole, single-throw switches.
Item |
Description |
Power source |
Power cable |
Horn |
Lamp |
Relay (100 mA coil current) |
Toggle switches to enable and disable lamp or horn alerts |
Item |
Wire Color |
Wire Function |
Red |
Power |
Black |
Ground |
Yellow |
Alarm |
