Additional Grounding Consideration
This consideration is applicable only to devices that have a grounding screw. Not all models have a grounding screw.
This device should not need additional chassis grounding in most installation situations. If you experience interference, the grounding screw on the housing can be used to connect the device to the water ground of the boat to help avoid the interference.
Power ground screw
GUID-6E54DB9C-BAE7-4C40-90F3-2D22E623703D v6
January 2025
