Power/NMEA 0183 Cable
  • The wiring harness connects the device to power, NMEA® 0183 devices, and a lamp or a horn for visible or audible alerts.
  • If it is necessary to extend the NMEA 0183 or alarm wires, you must use 22 AWG (.33 mm²) wire.
Cable diagram with callouts
Item
Wire Color
Wire Function
Callout number 1
Red
Power
Callout number 2
Black
Ground (power and NMEA 0183)
Callout number 3
Blue
NMEA 0183 internal port 1 Tx (Out)
Callout number 4
Brown
NMEA 0183 internal port 1 Rx (In)
Callout number 5
Gray
NMEA 0183 internal port 2 Tx (Out)
Callout number 6
Violet
NMEA 0183 internal port 2 Rx (In)
Callout number 7
Orange
Accessory on
Callout number 8
Yellow
Alarm low
GUID-6E54DB9C-BAE7-4C40-90F3-2D22E623703D v6
January 2025
