LED Light Configuration for a Fusion Stereo Using the ActiveCaptain App
You can connect your mobile device to a compatible Fusion® stereo using the ActiveCaptain® app to configure and control lights connected to a Garmin Spectra™ LED control module. If the stereo and LED control module are connected to the same NMEA 2000® network as a compatible chartplotter, you should connect the ActiveCaptain app to the chartplotter instead of the stereo so you can use the full features included in the app in addition to the lighting controls. See the owner's manual for the chartplotter for instructions.
NOTE:
Before you can connect your mobile device to the stereo, you must either configure the stereo to act as a wireless access point or connect the stereo to a wireless router using an Ethernet cable.
- Getting Started with the ActiveCaptain App
- Initializing Connected LED Lights Using the ActiveCaptain App
- Associating LED Lights with an Audio Zone
Parent Topic: Configuration
