Configuration
Before you can use lights connected to the Garmin Spectra™ LED control module, you must first configure each light using a Garmin® chartplotter or through the ActiveCaptain® app. Once configured, the LED lighting connected to the LED control module can be controlled through a compatible Garmin chartplotter or Fusion® stereo connected to the same NMEA 2000® network as the LED control module.
Using certain LED colors, such as red and green, may violate the laws, regulations, and standards related to the use and/or operation of marine navigation lights. It is the user's responsibility to comply with any such applicable laws, regulations, and standards. Garmin is not responsible for any fines, penalties, citations, or damages that may be incurred due to any such lack of compliance.
You can also configure LED lighting names, effects, and brightness levels. See the owner's manual for your chartplotter or stereo for complete operational and configuration instructions.
