Setup Overview
The first time you turn on your device, it walks you through using the windage and elevation adjustments on the mount to set your first aim point. After you set the first aim point, you can add aim points for different distances electronically. You can choose to calibrate your own aim points individually, or the scope can automatically calibrate aim points out to 80 meters or 80 yards, based on the speed of your crossbow. You can add, delete, or recalibrate aim points after completing the setup procedure.
If you auto-calibrate your aim points, you should validate your accuracy at 50 meters or 50 yards. It is especially important to validate your accuracy if you enter the crossbow manufacturer's advertised speed.
Parent Topic: Getting Started
