Setting the String Odometer
You can use the string odometer to keep track of how many shots you have taken with your bow string. You should reset the string odometer each time you replace the bow string.
- From the main menu, select .
- Select ENABLED.
- Enter the maximum string shot count for your bow string.
The device keeps track of the number of shots you have taken and counts down the number of shots remaining on your bow string.
Parent Topic: Settings
