Adjusting the Focus
You should adjust the eyepiece so your field of view and the information on the display are both in focus at the same time. You can use the focus adjustment page to help you adjust the focus.
- From the main menu, select .
- Adjust the eyepiece until you clearly see the image on the display and in your field of view at the same time (Adjusting the Eyepiece).
Parent Topic: Settings
