Installation Considerations
This device should be mounted in a location that is not exposed to extreme temperatures or conditions. The temperature range for this device is listed in the product specifications (Specifications). Extended exposure to temperatures exceeding the specified temperature range, in storage or operating conditions, may cause device failure. Extreme-temperature-induced damage and related consequences are not covered by the warranty.
When selecting a mounting location, you should observe these considerations.
Before selecting the mounting location, you should determine whether to connect an external GPS antenna or rely on the device's internal GPS antenna (External GPS Antenna Connection).
To avoid interference from the radio and fist mic hanger with a magnetic compass, you must observe the compass-safe distance listed in the product specifications (Specifications).
You should mount the fist mic within arm's reach of the device, so that you can reach both the device and the fist mic without moving.
The mounting location must not be covered by metal objects or surfaces that may interfere with the wireless connection between the device and the fist mic.
You should install at least one station in a location that allows you to operate the radio while you drive the boat.
You should consider connecting the device and the fist mic to the same circuit, so that both devices are always turned on and off together.
If you are upgrading from a different model, you may be able to reuse the existing cutout (Retrofit Kit Considerations).
The mounting location must have approximately 185 mm (7 1/4 in.) of space behind the mounting surface, to minimize strain on the cables and connectors on the back of the device.
If you are flush-mounting the device, the mounting surface material must be strong enough to support the weight of the device and protect it from excessive vibration or shock.
If necessary, you can bail-mount the device using the bail-mount kit (sold separately). You can purchase the bail-mount kit from your Garmin® dealer or you can go to garmin.com/SignalVHF-Accessories.
If you are installing the device in a location that may be exposed to water, you must mount it within 45 degrees of the horizontal plane so that water does not gather near the connectors on the back of the device. You should add a drip loop to all connected cables to allow water to drip off of the cables and avoid damage to the device.
