Specifications
Specification
Measurement
Dimensions (H x W x D)
Head unit: 75 x 160 x 104 mm (3.0 × 6.3 × 4.1 in.)
Fist mic: 100 × 60 × 31 mm (3.9 × 2.4 × 1.2 in.)
Weight
Head unit: 655 g (1.45 lbs.)
Fist mic: 245g (0.54 lbs.)
Operating temperature range
From −20° to 55°C (from −4° to 131°F)
Water rating
Head unit: IEC 60529 IPX6 and IPX71
Fist mic: IEC 60529 IPX72
Compass-safe distance
Head unit: 70 cm (27 9/16 in.)
Fist mic and fist mic hanger: 40 cm (15 3/4 in.)
Operating voltage
From 9.6 to 32 Vdc
Current draw @ 12 V
Head unit: 700 mA, 6 A maximum
Fist mic: 90 mA, 0.9 A maximum
VHF/AIS antenna connector
S0-239 (50 ohms)
Maximum antenna gain
6 dBi
Antenna port impedance
50 ohms
External GNSS antenna connector
SMA
Maximum fist mic speaker output power
5 W RMS, <1% THD
Maximum external speaker output power
15 W RMS, <1% THD, 4 Ω
Maximum hailer loudspeaker output power
25 W RMS, <1% THD, 4 Ω
Remote station support
Up to five Garmin Signal™ RM 100 remote stations
NMEA 2000® LEN @ 12.0 Vdc
1 (50 mA)
VHF Frequency Range
Tx: 156.025 – 162.025 MHz
Rx: 156.025 – 163.275 MHz
Wireless frequency and output power
156.025 – 162.025 MHz: < 44 dBm
2401 – 2473 MHz: < 16.5 dBm
2400 – 2480 MHz: < 10dBm
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min, and is protected against powerful jets of water. For more information, go to www.garmin.com/waterrating.
2 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
GUID-60E76EAD-A560-449E-A528-6C89D9026DB3 v1
May 2026
