Adjusting the Fine Heading Alignment
If you do not have a GPS source present on the Garmin BlueNet™ network or Garmin® Marine Network, the Auto Heading Alignment option is not available as part of menu-based calibration. You must adjust the Fine Heading Alignment instead.
You can adjust the Fine Heading Alignment in conjunction with Auto Heading Alignment to fine-tune the heading output (optional).
  1. Start the Spy Pole™ Mount heading sensor calibration, and skip directly to Fine Heading Alignment.
  2. Using a landmark or a known good compass, determine the heading of your boat.
  3. Adjust the heading until it matches your measurement.
  4. Select Done.
GUID-5E9D5954-EED9-410E-9E9E-D57EBC1DBAD3 v2
September 2026
