Spy Pole Heading Sensor Calibration
When you connect the Spy Pole™ mount with a paired heading sensor to a compatible Garmin® chartplotter, the Spy Pole™ Mount Setup Wizard will prompt you for calibration during setup. Otherwise, you can perform menu-based calibration through the Spy Pole™ mount toolbar on your chartplotter (Performing Menu-Based Calibration). Go to garmin.com for a list of compatible chartplotters.
NOTICE
After installation is complete, you must calibrate the Spy Pole™ heading sensor, as it does not provide heading data until it is calibrated.
GUID-5E9D5954-EED9-410E-9E9E-D57EBC1DBAD3 v2
September 2026
