Training Settings
The following options and settings allow you to customize your device based on your training needs. These settings are saved to an activity profile. For example, you can set time alerts for your road profile, and you can set an Auto Lap® position trigger for your mountain biking profile.
TIP: You can also customize the activity profiles from the device settings in the Garmin Connect™ app.
Select Menu symbol > Activity Profiles, and select a profile.
Alerts and Prompts
Sets how laps are triggered, and customizes the training or navigation alerts for the activity (Alerts and Prompts Settings).
Auto Lock
Enables the device to automatically lock the device buttons during a ride to prevent accidental button presses (Locking and Unlocking the Bike Computer).
Auto Sleep
Enables the device to automatically enter sleep mode after five minutes of inactivity (Using Auto Sleep).
Climbs
Enables the ClimbPro feature and sets terrain type and which types of climbs the device detects (Using ClimbPro).
Data Screens
Enables you to customize data screens and add new data screens for the activity (Adding a Data Screen).
Gear Selection
Enables you to select the gear or equipment for the activity after you complete and save an activity. You can add and delete gear in your Garmin Connect account.
MTB/CX
Enables grit, flow, and jump recording. Select this setting to enable jump alerts, if available. You can also turn ForkSight on and off in mountain biking activity profiles, such as Mountain or Enduro MTB (ForkSight).
TIP: You can select Enduro Mode to enable automatic or manual climb and descent detection for enduro activity profiles ( Biking Activity Profiles).
Navigation
Sets navigation messages, and customizes the map and routing settings (Map Settings) (Route Settings).
Nutrition/Hydration
Enables food and drink consumption tracking.
Ride Type
Sets the type of ride that is typical for this activity profile, such as commuting.
NOTE: After a ride that is not typical, you can manually update the ride type. Accurate ride type data is important for creating bike friendly courses.
Satellite Systems
Allows you to turn off GPS (Training Indoors), or set the satellite system to use for the activity (Changing the Satellite Setting).
Segments
Turns on your enabled segments (Enabling Segments).
Self Evaluation
Sets how often you evaluate your perceived effort for the activity (Evaluating an Activity).
Timer
Sets timer preferences. The Auto Pause option allows you to set when the activity timer automatically pauses (Using Auto Pause). The Timer Start Mode option enables you to set how the device detects the start of a ride and automatically starts the activity timer (Starting the Timer Automatically).
GUID-5951C9F9-0E2E-4ECC-A508-6F93D026685D v5
September 2026
