Product Updates
Your device automatically checks for updates when paired with a phone using Bluetooth® technology or when connected to Wi‑Fi®. You can manually check for updates from the system settings (System Settings). On your computer, install Garmin Express™ (garmin.com/express). On your phone, install the Garmin Connect™ app.
This provides easy access to these services for Garmin® devices:
  • Software updates
  • Map updates
    NOTE: Map updates are available through Garmin Express.
  • Data uploads to the Garmin Connect app on your phone
  • Product registration
Updating the Software Using the Garmin Connect App
Before you can update your device software using the Garmin Connect app, you must have a Garmin Connect account, and you must pair the device with a compatible phone (Pairing Your Phone).
Sync your device with the Garmin Connect app.
When new software is available, the Garmin Connect app automatically sends the update to your device.
Updating the Software Using Garmin Express
Before you can update your device software, you must have a Garmin Connect account, and you must download the Garmin Express application.
  1. Connect the device to your computer using the USB cable.
    When new software is available, Garmin Express sends it to your device.
  2. Follow the on-screen instructions.
  3. Do not disconnect your device from the computer during the update process.
    NOTE: If you have already set up your device with Wi‑Fi connectivity, Garmin Connect can automatically download available software updates to your device when it connects using Wi‑Fi.
GUID-5951C9F9-0E2E-4ECC-A508-6F93D026685D v5
September 2026
