Updating the Software Using a USB Flash Drive
You can update the device software using a USB flash drive.
NOTICE
Do not turn off the device or disconnect the power during a software update. Turning off the power during a software update may cause the device to become unresponsive.
NOTE:
  • You cannot update the software using a USB flash drive formatted using the NTFS file system. If you encounter problems updating the device, format the USB flash drive using FAT32 and try the update process again.
  • The device may restart a few times while updating the software. This is expected behavior.
  • You can program only newer versions of software on the device.
NOTE: If the stereo you want to update is in a group, you must remove it from the group (Leaving a Group).
  1. Select an option to prepare the USB flash drive for updating the stereo software:
  2. After you prepare the USB flash drive with the software-update files, select an option to update the stereo:
GUID-53FC9B2D-25AD-45AB-A2A1-50C08CBD5001 v7
September 2024
