Updating the Software from a Prepared USB Flash Drive
Before you update the software, you must load the software update files onto a suitable USB flash drive either manually (Downloading a Software Update Manually) or by using the Garmin Express™ app (Downloading a Software Update using the Garmin Express App).
NOTICE
Do not turn off the stereo or disconnect the power during a software update. Turning off the power during a software update may cause the stereo to become unresponsive.
NOTE: The stereo may restart a few times while updating the software. This is expected behavior.
  1. Turn on the stereo.
  2. After the stereo boots fully, insert the USB flash drive into the USB port.
    NOTE: In order for the update prompt to appear automatically, you must allow the device to fully boot before inserting the USB flash drive.
  3. If you are prompted to update the software automatically, select Install Now to start the update and skip the next step.
  4. If the update prompt does not appear automatically, select an option:
    • To update the stereo software, select Menu button > SETTINGS, select the name of the stereo, then select UPDATE > UPDATE DEVICES.
    • To update accessories connected to the stereo, select Menu button > SETTINGS, select the name of the stereo, then select UPDATE > ACCESSORIES and select the name of the accessory you want to update.
      NOTICE
      To ensure all accessories are updated properly, you should update the stereo software first, then update the accessories.
    The Device activity symbol LED flashes four times and repeats while the software update is in progress.
  5. Wait several minutes while the update process completes.
  6. Leave the USB flash drive in place while the stereo restarts automatically.
  7. After the stereo fully boots after restarting, remove the USB flash drive.
    NOTE: If the USB flash drive is removed before the device restarts fully, the update is not complete.
GUID-53FC9B2D-25AD-45AB-A2A1-50C08CBD5001 v7
September 2024
