The status LED flashes red while charging
  • If the device has been exposed to moisture, disconnect the charging cable, leave the weather cap open, and allow the charging port to dry completely.
  • Check the USB cable, connectors, and ports for damage.
  • Make sure the AC adapter or computer USB port is generating power.
    You can check this several ways. For example, you can check whether other devices powered by the source are functioning.
  • Charge the device within the approved charging temperature range (Specifications).
GUID-50AF77F9-6AD5-45A2-B352-C882BE5DE2B7 v2
August 2026
