Race Calendar and Primary Race
When you add a race event to your Garmin Connect™ calendar, you can view the event on your watch by adding the primary race glance (Glances). The event date must be in the next 365 days. The watch displays a countdown to the event, your goal time or predicted finish time (running events only), and weather information.
Race calendar
NOTE: Historical weather information for the location and date is available right away. Local forecast data appears approximately 14 days before the event.
If you add more than one race event, you are prompted to choose a primary event.
Depending on the available course data for your event, you can view elevation data, the course map, and add a PacePro™ plan (PacePro Training).
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
