PacePro Training
Many runners like to wear a pace band during a race to help achieve their race goal. The PacePro™ feature allows you to create a custom pace band based on distance and pace or distance and time. You can also create a pace band for a known course to optimize your pace effort based on elevation changes.
You can create a PacePro plan using the Garmin Connect™ app. You can preview the splits and elevation plot before you run the course.
Downloading a PacePro Plan from Garmin Connect
Before you can download a PacePro plan from Garmin Connect, you must have a Garmin Connect account (Garmin Connect).‍
  1. Select an option:
  2. Select Training & Planning > PacePro Pacing Strategies.
  3. Follow the on-screen instructions to create and save a PacePro plan.
  4. Select Sending data symbol or Send to Device.
Starting a PacePro Plan
Before you can start a PacePro plan, you must download a plan from your Garmin Connect account (Downloading a PacePro Plan from Garmin Connect).
  1. From the watch face, press Upper-right button.
  2. Select an outdoor running activity.
  3. Scroll down to select Training > PacePro Plans.‍
  4. Select a plan.
    TIP: You can scroll down to preview the splits and elevation plot before you accept the PacePro plan.
  5. Press Upper-right button.
  6. Select Use Plan to start the plan.
  7. If necessary, select Check mark to enable course navigation.
  8. Press Upper-right button to start the activity timer.
    PacePro feature with callouts
    1
    Target split pace
    2
    Current split pace
    3
    Completion progress for the split
    4
    Distance remaining in the split
    5
    Overall time ahead of or behind your target time
    TIP: You can hold Middle-left button, and select Stop PacePro > Check mark to stop the PacePro plan. The activity timer continues running.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
