Controls
The controls menu lets you quickly access watch features and options. You can add, reorder, and remove the options in the controls menu (Customizing the Controls Menu).
From any screen, hold Upper-left button.
Controls menu
Icon
Name
Description
Altimeter, barometer, and compass
ABC
Select to open the altimeter, barometer, and compass app.
Airplane mode
Airplane Mode
Select to enable airplane mode to turn off all wireless communications.
Alarm clock
Alarm Clock
Select to add or edit an alarm (Setting an Alarm).
Alternate time zones
Alt. Time Zones
Select to view the current time of day in additional time zones (Adding Alternate Time Zones).
Assistance
Assistance
Select to send an assistance request (Requesting Assistance).
Battery saver
Battery Saver
Select to enable the battery saver feature (Customizing the Battery Saver Feature).
Brightness
Brightness
Select to adjust the screen brightness (Display and Brightness Settings).
Broadcast heart rate data
Broadcast Heart Rate
Select to turn on heart rate broadcasting to a paired device (Broadcasting Heart Rate Data).
Calculator symbol
Calculator
Select to use the calculator, including the tip calculator.
Calendar
Calendar
Select to view upcoming events from your phone calendar.
Camera
Camera Controls
Select to manually take a photo and record a video clip (Using the Varia Camera Controls).
Clocks
Clocks
Select to open the Clocks app to set an alarm, timer, stopwatch, or view alternate time zones (Clocks).
Red shift
Color Shift
Select to turn the screen to shades of red, green, or orange to use the watch in low light conditions.
Display on or off
Display
Select to turn off the screen for alerts, gestures, and Always On Display mode (Display and Brightness Settings).
Do not disturb
Do Not Disturb
Select to enable do not disturb mode to dim the screen and disable alerts and notifications. For example, you can use this mode while watching a movie.
Find my phone
Find My Phone
Select to play an audible alert on your paired phone, if it is within Bluetooth® range. The Bluetooth signal strength appears on the Forerunner® watch screen, and it increases as you move closer to your phone.
Flashlight control symbol
Flashlight
Select to turn on the screen to use your watch as a flashlight (Using the Flashlight Screen).
Focus mode
Focus Mode
Select to change the current focus mode (Focus Modes).
Garmin Share
Garmin Share
Select to open the Garmin Share app (Garmin Share).
History
History
Select to view your activity history, records, and totals.
Lock
Lock Device
Select to lock the buttons and the touchscreen to prevent inadvertent presses and swipes.
Messenger
Messenger
Select to view and send messages using the Messenger app (Using the Messenger Feature).
Music
Music
Select to control music playback (Listening to Music on Your Phone).
NOTE: You can also download music to your Forerunner 170 Music watch (Listening to Music).
Notifications
Notifications
Select to view calls, texts, social network updates, and more, based on your phone notification settings (Enabling Phone Notifications).
Phone
Phone
Select to disable Bluetooth technology and your connection to your paired phone.
Power off
Power Off
Select to turn off the watch.
Pulse oximeter
Pulse Oximeter
Select to open the pulse oximeter app (Pulse Oximeter).
Save location
Save Location
Select to save your current location to navigate back to it later.
Settings symbol
Settings
Select to open the settings menu.
Silent mode symbol
Silent Mode
Select to enable silent mode to disable all sounds.
Stopwatch
Stopwatch
Select to start the stopwatch (Using the Stopwatch).
Sunrise and sunset
Sunrise & Sunset
Select to view sunrise, sunset, and twilight times.
Sync
Sync
Select to sync your watch with your paired phone.
Time sync
Time Sync
Select to sync your watch with the time on your phone or using satellites.
Timer
Timer
Select to set a countdown timer (Using the Countdown Timer).
Touch
Touch
Select to disable touchscreen controls.
Touch lock
Touch Lock
Select to enable swiping down from the top of the screen to unlock the touchscreen.
Wallet
Wallet
Select to open your Garmin Pay™ wallet and pay for purchases with your watch (Garmin Pay).
Weather
Weather
Select to view the current weather forecast and current conditions.
Wi-Fi
Wi-Fi
Select to disable Wi‑Fi® communications.
NOTE: This feature is not available for all product models.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
