Using the Messenger Feature
CAUTION
The non-satellite messaging features of the Garmin Messenger™ app alone should not be relied on as a primary method to obtain emergency assistance.
NOTICE
To use the Messenger feature, your Forerunner® watch must be connected to the Garmin Messenger app on your compatible phone using Bluetooth® technology.
The Messenger feature on your watch allows you to view, compose, and reply to messages from the Garmin Messenger phone app.
  1. From the watch face, press Lower-left button to view the Messenger glance.
    TIP: The Messenger feature is available as a glance, app, or controls menu option on your watch.
  2. Select the glance.
  3. If this is your first time using the Messenger feature, scan the QR code with your phone, and follow the on-screen instructions to complete the pairing and setup process.
  4. On your watch, select an option:
    • To compose a new message, select New Message, select a recipient, and either select a pre-defined message or compose your own.
    • To view a conversation, scroll down, and select a conversation.
    • To reply to a message, select a conversation, select Reply, and either select a pre-defined message or compose your own.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
