Viewing or Editing Course Details
You can view or edit course details before you navigate a course.
  1. From the watch face, press Upper-right button.
  2. Select a GPS activity.
  3. Scroll down, and select Navigate > Courses.
  4. Select a course.
  5. Press Upper-right button
  6. Select an option:
    • To begin navigation, select Do Course.
    • To view course points, such as water stops, obstacles, or steep climbs, select View Course Points.
      TIP: You can add course points when you create a course on the Garmin Connect™ app (Creating a Course on Garmin Connect ).
    • To create a custom pace band, select PacePro (PacePro Training).
    • To view the course on the map and pan or zoom the map, select Map.
    • To begin the course in reverse, select Do Course in Reverse.
    • To view an elevation plot of the course, select Elevation Plot.
    • To change the course name, select Name.
    • To delete the course, select Delete.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
