Tools, Supplies, and Equipment Needed
  • Suitable workbench or table
    • Must be at least 8 ft. (2.5 m) long for working on the 50 in. models
    • Must be at least 10 ft. (3 m) long for working on the 57 in. models
  • #0, #1, #2, and #3 Phillips screwdrivers
  • 3/32 in., 3 mm, 4 mm, and 8 mm hex bits or wrenches
  • 10 and 15 mm socket
  • T-10 TORX® screwdriver (for removing the electronics cover)
  • 29 mm socket or wrench (for replacing the PCB)
  • 9/16 in. (15 mm) socket (for removing the propeller)
  • 36 mm or adjustable wrench (for replacing the coil cable)
  • Torque wrench
    • With 4 mm, 6 mm, and 8 mm hex bits
    • Capable of measuring torque from 0.5 N-m (4.5 lbf-in) to 17 N-m (150 lbf-in)
  • Synthetic or marine grade general-purpose grease
  • Needle-nose pliers
  • Dielectric grease (for replacing the power cable or coil cable)
GUID-4961C943-E6C7-423B-AC7D-40EC5C713247 v2
July 2026
