Activating the Sleep Band Remove the protective film from the sensor on the back of the module. Plug the cable ( end) into the charging port. Plug the other end of the cable into a USB charging port. The LED flashes in active pairing mode (Pairing Your Device with the Garmin Connect App). Parent Topic: IntroductionHomeIntroductionActivating the Sleep Band
