Calibrating the Compass
NOTE:
You must calibrate the electronic compass outdoors. Do not stand near objects that influence magnetic fields, such as cars, buildings, or overhead power lines.
Your device was already calibrated at the factory, and the device uses automatic calibration by default. If the Xero® locations feature is not working properly, for example, after moving long distances or after extreme temperature changes, you can manually calibrate the compass.
- From the main menu, select .
- Follow the on-screen instructions.
Parent Topic: System Settings
