Fixed Pins
You can set the bow sight to use fixed pins for multiple ranges. This enables the bow sight to work like a conventional fixed pin sight. The device automatically creates fixed pins in 10 m (10 yd.) increments for auto-calibrated profiles. Fixed pins have a lower power requirement than the laser rangefinder, and you can use fixed pins if your battery is too low to range. You can set fixed pins for any range between the highest and lowest calibrated ranges.
When using hunt mode, you can press
or quickly tap the ranging trigger to display fixed pins at any time.
Parent Topic: Pin Calibration
