Managing Arrow Profiles
From the main menu, select
- Select an arrow profile.
Select an option:
To activate the profile, select Activate.
To adjust the calibrated ranges for the profile, select Calibrated Ranges.
To adjust the fixed pins for the profile, select Fixed Pins.
To change the type of arrow tip for the profile, select Arrow Tip.
To change the arrow diameter for the profile, select Arrow Diameter.
To validate the pin stack, select Validate Stack or Validated Stack.
To edit the profile name, select Edit Name.
To reset all calibration data for the current profile, select Reset Profile.
To delete the profile, select Delete.
Parent Topic: Adding Arrow Profiles
