Validating the Pin Stack
The device prompts you to validate the pin stack after auto-calibration. If you choose to skip validation during setup, you can validate the pin stack later through the arrow profile's settings. You can also re-validate a pin stack that has been previously validated.
NOTE:
You can also manually calibrate the ranges in your arrow profile. Manually calibrating ranges from an auto-calibrated pin stack removes the validation option from the arrow profile and turns the profile into a manual profile. You can recreate the original profile with auto-calibration, if necessary.
Select
- Select an arrow profile.
- Select Validate Stack or Validated Stack.
- Select Yes.
- Follow the on-screen instructions to validate or re-validate the pin stack.
Parent Topic: Automatically Calibrating Pins
