Adjusting the Roll Axis
For best results, you should adjust the roll axis on your bow sight after mounting it to your bow.
It is possible for your bow's sight plane to shift from vertical at rest to canted at full draw due to riser flex. If this occurs, repeat this process with the bow safely at full draw using a draw board.
Parent Topic: Advanced Setup
