Taring the Digital Level
After you have mounted your bow sight to your bow, the digital level should display 0 when the bow is level. If it does not display 0, you may need to tare the digital level.
- Select .
- Hold the bow level.
- Press OK.
- If necessary, adjust the bubble level so it is centered when the digital level reads 0 (Adjusting the Bubble Level).
Parent Topic: Advanced Setup
