Removing an MOB Tag
If you no longer want to use a paired MOB tag, you can remove it from the system.
NOTE: At least one MOB tag with the Captain role assigned must be paired for the Garmin OnBoard™ engine cutoff system to function. You cannot remove a tag if it is the only tag paired with the Captain role assigned.
  1. On a connected chartplotter, select Settings menu > Communications > Wireless Devices > OnBoard MOB System > MOB Tags.
  2. Select the MOB tag you want to remove.
  3. Select Review > Remove Device.
September 2026
