Garmin OnBoard Man Overboard Engine Cutoff System
CAUTION
For the best possible performance and to avoid potential injury, damage to the device, or damage to your vessel, installation by a qualified marine installer is recommended.
NOTICE
The following instructions apply to the Garmin OnBoard™ system only. If you have a Yamaha® vessel with a Wireless Station and MOB tags, refer to the instructions provided with your Yamaha Wireless Station manual when using and configuring your Yamaha MOB tags.
If you have installed a Garmin OnBoard man overboard Engine Cutoff System (ECOS) on your boat, you can use the chartplotter to interact with and customize the system.
You must install and test the Garmin OnBoard engine cutoff system before using it on your vessel. Follow the Garmin OnBoard Engine Cutoff System Installation Instructions provided in the product box to install and test the system.
GUID-3E67C80C-0812-4EEC-BC60-699751B9CF6F v15
June 2026
