Changing the Backlight Settings
- Hold MENU.
- Select .
- Select Night Vision to reduce the backlight intensity for compatibility with night vision goggles (optional).
Select an option:
Select During Activity.
Select Not During Activity.
Select During Sleep.
Select an option:
Select Keys to turn on the backlight for key presses.
Select Alerts to turn on the backlight for alerts.
Select Gesture to turn on the backlight by raising and turning your arm to look at your wrist.
Select Timeout to set the length of time before the backlight turns off.
Select Brightness to set the brightness level of the backlight.
NOTE: If you enable night vision mode, you cannot adjust the brightness level.
Parent Topic: System Settings
