System Settings
Hold MENU, and select System.
Language
Sets the language displayed on the device.
Time
Adjusts the time settings (Time Settings).
Backlight
Adjusts the backlight settings (Changing the Backlight Settings).
Sounds
Sets the device sounds, such as key tones, alerts, and vibrations.
Do Not Disturb
Turns on or off do not disturb mode. Use the During Sleep option to turn on do not disturb mode automatically during your normal sleep hours. You can set your normal sleep hours on your Garmin Connect™ account.
Hot Keys
Allows you to assign shortcuts to device keys (Customizing the Hot Keys).
Auto Lock
Allows you to lock the keys automatically to prevent accidental key presses. Use the During Activity option to lock the keys during a timed activity. Use the Not During Activity option to lock the keys when you are not recording a timed activity.
Units
Sets the units of measure used on the device (Changing the Units of Measure).
Format
Sets general format preferences, such as the pace and speed shown during activities, the start of the week, and geographical position format and datum options.
Data Recording
Sets how the device records activity data. The Smart recording option (default) allows for longer activity recordings. The Every Second recording option provides more detailed activity recordings, but may not record entire activities that last for longer periods of time.
USB Mode
Sets the device to use MTP (media transfer protocol) or Garmin® mode when connected to a computer.
Reset
Allows you to reset user data and settings (Resetting All Default Settings).
Software Update
Allows you to install software updates downloaded using Garmin Express™. Use the Auto Update option to enable your device to download the latest software update when a Wi‑Fi® connection is available.
About
Displays device, software, license, and regulatory information.
Copyright © Garmin. All rights reserved.GUID-3B607AEB-9EB5-4BF3-A38D-1F9926BB9F65 v5
