Turning Off Wrist-based Heart Rate While Swimming
Wrist-based heart rate is turned on by default for swim activities. The device is also compatible with the HRM-Pro™ accessory and the HRM-Swim™ accessory. If both wrist-based heart rate and chest heart rate data are available, your device uses the chest heart rate data.
  1. From the heart rate widget, hold MENU.
    NOTE: You may need to add the widget to your widget loop (Customizing the Widget Loop).
  2. Select Heart Rate Options > While Swimming > Off.
Copyright © Garmin. All rights reserved.GUID-3B607AEB-9EB5-4BF3-A38D-1F9926BB9F65 v5
