Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Hold MENU.
  2. Select Widgets.
  3. Select Widget Glances to turn widget glances on or off.
    NOTE: Widget glances display summary data for multiple widgets on a single screen.
  4. Select Edit.
  5. Select a widget.
  6. Select an option:
    • Press UP or DOWN to change the location of the widget in the widget loop.
    • Select Delete to remove the widget from the widget loop.
  7. Select Add.
  8. Select a widget.
    The widget is added to the widget loop.
Copyright © Garmin. All rights reserved.GUID-3B607AEB-9EB5-4BF3-A38D-1F9926BB9F65 v5
