Radar Status LED
LED Activity
Status
Flashing blue
Bluetooth®
The device is in Bluetooth pairing mode. The light will flash for three minutes, until a Bluetooth device is paired, or until the device button is pressed.
Solid yellow
Demo
The device is in demo mode.
Solid orange
Error
The device is experiencing degraded performance because the rear sensor is obstructed.
Solid red
Error
The device is not operational because of a system error.
Solid green
Normal operation
The device is operating normally.
Solid blue
Normal operation
The device features are limited because the motorcycle is traveling at a low rate of speed.
Single green flash (after button press)
Normal operation
The indicator and rear lights are enabled.
Single yellow flash (after button press)
Normal operation
The indicator lights are enabled. The rear lights are off, but radar detection is working.
Three green flashes (after three button presses)
Normal operation
Three orange flashes (after three button presses)
Normal operation
The indicator lights are disabled. The rear lights are off, but radar detection is working.
Solid or flashing magenta
Update
The device is performing a software update and is disabled until the update is complete.
20 green flashes on startup
Update
The device performed a successful update.
20 red flashes on startup
Update
The device failed to perform a software update.
GUID-3B03A850-46B2-47F7-B7AF-7CD84686A1DA v3
August 2026
