Tools and Supplies Needed
  • Drill and a 5/16 in. (8 mm) drill bit
  • #1 Phillips screwdriver
  • #2 Phillips screwdriver
  • 3 mm and 4 mm hex bits or wrenches (two 4 mm recommended)
  • 9/16 in. (14 mm) socket
  • Torque wrench
  • Circuit breaker rated for continuous 60 A
  • Trolling motor plug and receptacle rated for 60 A or greater (optional)
  • 6, 4, or 2 AWG (16, 25, or 35 mm2) wire for extended runs of the power cable
  • Solder and heat-shrink tubing, if extending the power cable
  • Stainless steel pan head 1/4-20 (M6x1) bolts (if the included bolts are not long enough to mount the motor to the deck)
GUID-3A9C1CE0-D2CD-4415-B65F-6F1FF9701E2D v3
August 2026
