Setting Your Heart Rate Alerts
You can set the device to alert you when your heart rate is above or below a target zone or a custom range. For example, you can set the device to alert you when your heart rate is below 150 beats per minute (bpm).
  1. Hold UP.
  2. Select Menu symbol > Activities & Apps.
  3. Select an activity.
    NOTE: This feature is not available for all activities.
  4. Select the activity settings.
  5. Select Alerts > Add New > Heart Rate.
  6. Select an option:
    • To use the range of an existing heart rate zone, select a heart rate zone.
    • To customize the maximum value, select Custom > High, and enter a value.
    • To customize the minimum value, select Custom > Low, and enter a value.
Each time you exceed or drop below the specified range or custom value, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
GUID-3A791586-B59F-4B37-B9C5-5A41F8C6BE0B v8
December 2025
