Autopilot
WARNING
You are responsible for the safe and prudent operation of your vessel. The autopilot is a tool that enhances your capability to operate your boat. It does not relieve you of the responsibility of safely operating your boat. Avoid navigational hazards and never leave the helm unattended.
WARNING
Always be prepared to promptly regain manual control of your boat.
WARNING
Learn to operate the autopilot on calm and hazard-free open water.
WARNING
Use caution when operating the autopilot near hazards in the water, such as docks, pilings, and other boats.
Pairing With an Autopilot
You can pair your watch with a compatible Garmin® autopilot to steer your vessel from your watch.
  1. Bring your quatix® watch within 3 m (10 ft.) of the marine device.
  2. From the watch face, press Upper-right button, and select Autopilot.
  3. Set your compatible Garmin autopilot helm control to search for a remote control.
    See your autopilot helm control owner's manual for more information.
  4. Follow the on-screen instructions on both devices to complete the pairing process.
After you pair the devices, they connect automatically when turned on, within range, and the app is open on the watch.
NOTE: If you need to pair with another autopilot helm control, in the Autopilot app, hold Middle-left button and select Settings > Pair New.
Controlling the Autopilot
  1. From the watch face, press Upper-right button, and select Autopilot.
  2. Select an option:
    • To engage the autopilot heading hold, hold a steady course, press Upper-right button, and release the helm.
    • To change the heading, with the autopilot engaged, press Middle-left button for starboard and Lower-left button for port.
    • To change the steering mode, hold Middle-left button, select Steering Mode, and select an option.
    • To perform a steering pattern, hold Middle-left button, select Pattern Steering, and select a pattern.
      NOTE: You can change the steering patterns available on your watch from your autopilot.
    • To take the helm and place the autopilot in standby mode, press Upper-right button.
GUID-3A4F9C4A-8735-46C0-8DA9-65F11400B150 v7
September 2026
