Golf Menu
During a round, you can select Menu symbol to access additional features in the golf menu.
Virtual Caddie
Requests a club recommendation from the virtual caddie (Virtual Caddie).
Scorecard
Opens the scorecard for the round (Keeping Score).
PinPointer
The PinPointer feature is a compass that points to the pin location when you are unable to see the green. This feature can help you line up a shot even if you are in the woods or in a deep sand trap (Viewing the Direction to the Pin).
NOTE: Do not use the PinPointer feature while the device is mounted to a bag or golf cart. Magnetic interference from the bag or cart can affect the accuracy of the compass.
Wind
Opens a pointer that shows the wind direction and speed relative to the pin (Viewing the Wind Speed and Direction).
Measure Shot
Allows you to measure the distance to your ball (Measuring a Shot).
Custom Targets
Allows you to save a location, such as an object or obstacle, for the current hole (Saving Custom Targets).
Add Back Nine
Allows you to add the back nine holes to play in the second half of a golf round.
NOTE: This setting only appears when you are playing a 9-hole course.
Change Green
Allows you to change the green when more than one green is available for a hole.
Settings
Allows you to customize the device settings and features ( Settings).
End Round
Ends the current round (Ending a Round).
GUID-39C10EC9-3CDF-406D-9BC9-8F490036536A v3
August 2026
