Adjusting Additional Audio Settings for a Zone
- Select .
- Select the name of the stereo.
- Select ZONE.
- Select a zone.
Select one or more options:
To limit the maximum volume output of this zone, select VOLUME LIMIT, and adjust the level.
To adjust the right and left speaker balance of this zone, select BALANCE, and adjust the balance.
To reduce the power output to the external amplifier associated with this zone, select EXT. AMP GAIN, and adjust the gain level.
To reduce the power output to the internal amplifier associated with this zone, select INT. AMP GAIN, and adjust the gain level.
NOTE: This setting is available only for zones associated with an internal amplifier, typically zones 1 and 2. -
To change the output of this zone from stereo to mono, select MONO.
NOTE: The mono setting is useful if a listening position is closer to one speaker than the other and predominantly hear only that channel. The mono setting combines both channels in each speaker in the zone.
Parent Topic: Speaker Zone Settings
