Naming the Device
You should provide a unique name for this device so you can easily identify it when viewing devices on the Fusion PartyBus™ network.
NOTE: You should provide unique names for all of the devices and zones on the network to avoid confusion when grouping, controlling, and setting up stereos and zones. You should also turn off zones that are not in use (Speaker Zone Settings).
For further customization, you can provide unique names for the sources on each stereo and turn off unused sources (General Settings).
  1. Select Menu button > SETTINGS.
  2. Select the device to rename.
  3. Select DEVICE NAME, and select an option:
    • Select a pre-defined name from the list.
    • Select CUSTOM NAME, and enter a unique name for the device.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
