Connecting the FUSION PartyBus Device to a Wireless Access Point
  1. Select Apps > Tools > Music > Settings > NETWORK > WI-FI CLIENT > SSID.
    A list of wireless access points within rage appears.
  2. Select the FUSION PartyBus™ wireless access point.
  3. Select an option:
    • To enter the password, select PASSWORD, enter the password, and select Enabled.
    • If you are connecting to the wireless access point using WPS, verify that WPS has been enabled on the access point, and select WPS.
      NOTE: It can take up to two minutes to successfully connect to the access point after you select WPS.
  4. Select SAVE.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
