Audio Settings
Select Apps > Tools > Music > Settings.
NOTE: When an option button is filled, the option is on. When the option button is clear, the option is off.
ZONE
Enables you to configure the speaker zones (Speaker Zone Settings).
TUNER REGION
Sets the region used by the various radio sources.
DEVICE NAME
Sets a name for this stereo.
SEARCHING
Enables FUSION® Alpha Search Technology (FAST), which allows you to quickly search for tracks by letter or number. You can set the minimum number of tracks required to enable the FAST menu. FAST searching is available when your device contains more than this minimum number of tracks.
AirPlay PASSWORD
Sets a password that a user must enter when connecting to the stereo using the AirPlay® feature.
SOURCE
Sets options for audio sources available on the stereo dock. You can enable or disable sources, rename sources, or set which sources the device can stream over the FUSION PartyBus™ network (Source Settings).
NETWORK
Enables you to configure the network settings ( Network Configuration).
DISPLAY
Sets the Music app to display day or night colors. You can select AUTO to allow the device to automatically set day or night colors based on the time of day.
ABOUT
Shows the software version information for the stereo.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
