Setting a Static IP Address
If the stereo is configured as a DHCP server, it is automatically assigned the IP address of 192.168.0.1. You can change this IP address.
If the stereo is a client on the network and you do not want the DHCP server to automatically assign an IP address to the stereo, you can set a static IP address.
NOTE: Every device on the network must have a unique IP address. If you select a static IP address that is the same as the IP address on the network, the devices will not work properly.
  1. Select Apps > Tools > Music > Settings > NETWORK > ADVANCED > WI-FI IP > STATIC IP.
  2. Select an option:
    • To set the IP address, select IP, and enter the IP address.
    • To set the subnet mask, select MASK, and enter the subnet mask.
      NOTE: The subnet mask must match all other devices on the network to work properly. A typical subnet mask is 255.255.255.0.
    • To set the default gateway IP address, select GATEWAY, and enter the gateway IP address.
      NOTE: The default gateway is typically set as the IP address of the DHCP server on the network.
  3. Select Save.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
